01-05-2019 18:51
01-05-2019 18:51
I have had my Versa for two weeks and had issues from the beginning with sleep tracking. It would track two hours when I slept 8. I decided to switch wrists and it will track correctly on my right wrist. I did a restart to see if that would fix it and it will not show sleep at all on my left wrist now. It does occasionally show naps on my left wrist, since this is the wrist I wear it on. I took a nap, then took it off for 1 1/2 hours and it had recorded the time off my wrist as sleep (on the left wrist). When I put it back on it stopped the sleep recording. It is a bit annoying to have to switch wrists at night, if I forget I have zero sleep data.
01-06-2019 01:19
01-06-2019 01:19
Yes it would be annoying! But I would guess it is due to your blood vessel position and blood flow at night, so the tracker doesnt get a consistant heart rate reading, so I doubt you will be able to fix it. It works on your other wrist so it is not a tracker issue.
Helen | Western Australia
01-07-2019 01:30
01-07-2019 01:30
