05-10-2020
07:11
05:02
05-10-2020
07:11
05:02
I’ve had my Fitbit Versa since Feb 2019. Earlier today it turned off and the screen says it has 0% battery. I’ve tried charging it but nothing’s happening. It still won’t switch on. I can see others have had this problem, has anyone managed to fix the issue?
05-10-2020 11:35
05-10-2020 11:35
Did you try restarting it while on the charger? If you can't see anything while on the charger i would say you have a bad charger cord.
05-11-2020 10:54
05-11-2020 10:54
Yes I’ve tried another charger, plug and socket and it’s all the same. The last time it sync (Sunday morning), it was on 81% and then just turned off.
05-11-2020 11:32
05-11-2020 11:32
No, I meant the charger cable may be bad.
05-11-2020 12:24
05-11-2020 12:24
I've replaced everything that charges the watch - the cable, the plug and the socket. The problem cannot be with it charging. The only thing I haven't replaced is the watch.
05-11-2020 12:34
05-11-2020 12:34
You're not alone. I'm having this same problem and have tried everything short of replacing the watch.
05-11-2020 12:40
05-11-2020 12:40
I'm having this exact issue with my versa.
05-11-2020 13:57
05-11-2020 13:57
I'm having the exact same issue! Last sync was 8am Sunday morning! I've tried everything!
05-11-2020
15:42
05:05
05-11-2020
15:42
05:05
Good day Family Please Help. I having problems with my device My device was not synchronizing as it normally would. I noted my time setting were out on my versa and then after many attempts to sync with my iphone I decided to cold boot by shutting down in the settings option in the menu and switching it back on using the back(left) button. After shutting down a gave it a minute or so and pressed this button but nothing happened the battery is charged as I had done so just the night before this issue. Please help me am I doing something wrong because this was a replacement pebble 😭 My versa helps me with balance especially now during lock down.
Moderator edit: additional information
05-13-2020 00:23
05-13-2020 00:23
I bought mine through Amazon and found out that it has a two year repair warranty. I’m posting it back today to hopefully be fixed. It’s very annoying as obviously a common problem with these watches!
05-19-2020 05:14
05-19-2020 05:14
Hello everyone. I'm sorry for the late response and hearing that your Versa smartwatches are not charging. I'm here to help you.
Hello @Dwight88. We apologize for the late response to the email you sent to our Support Team on May 11th. Keep in mind that we may need more than 7 business days to respond, due to recent events affecting our operations. Stay tuned of your inbox to the email address associated with this account someone will reply to you as soon as they can. In the meantime, you can try what I'm suggesting below.
Hi guys @DW1978, @Sistashirley, @nkr0701, and @Nikkinik81, thanks for taking the time to follow all the tips and recommendations suggested in the foros. If you're still having issues with your Versa's display, battery not charging or battery draining quickly, I'd recommend making sure you did follow as described below to solve the issue:
- Restart your watch as follows: How do I restart my Fitbit device?
- If your Versa does not charge, see: Why isn't my Fitbit device's battery charging?
On a side note, as per the description of your posts, it seems that your watches have insufficient power source. Where do you charge your tracker? Have you checked if by any chance the USB port or outlet is faulty? If you haven't done so, try a different port. A UL-certified wall charger will also work. Don't use a USB hub.
Here are some of the best tips to charge your Fitbit:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
If your Versa's battery is or keeps draining, see: Can I extend my Fitbit device's battery life?
Hey @SunsetRunner, thanks for your help in this thread! 😊
Let me know how it goes, I'll be around.
05-19-2020 06:01
05-19-2020 06:01
Its definitely my Fitbit that is faulty and looking at other messages, it looks like this is a common problem with Fitbit Versas.
I always use the official Fitbit Versa charger that came with the watch.
I have tried replacing ALL charging parts, apart from the watch. I used another OFFICIAL Fitbit Versa charger, changed the USB plug and changed the socket.
The last time my watch synced with my phone, it had 81% battery. An hour or so later, it had switched off and wouldn't charge or turn back on. It DEFINITELY had not run out of battery.
I have tried ALL the suggestions on the Fitbit website and nothing has made any difference at all.
I bought mine from Amazon and it has a 2 year repair warranty so I have now returned mine to them.
05-19-2020 06:27
05-19-2020 06:27
Hello @DW1978, thanks for getting back and for the update. I'm sorry to hear that the steps haven't worked, we appreciate all your efforts in solving the issue with your Versa's battery.
Thanks for letting us know that you've sent your Versa to Amazon as it's still under warranty with them, we hope they get you back on track soon.
If you need further assistance, don't hesitate to let me know, I'll be around.
06-09-2020 05:16
06-09-2020 05:16
Just to update, Fitbit have now sent me a brand new replacement watch. I'm assuming when I returned mine to Amazon, they realised it was irreparable and sent it back to Fitbit. Fitbit then got in contact with me and sent me a replacement watch.
