07-16-2020
13:39
08:53
07-16-2020
13:39
08:53
My versa wont charge nor will it turn on. Ive tried holding down the back and bottom
right buttons for 10 seconds and for several minutes. Ive tried a factory reset but it seems to have died.
Not impressed at all. What can I do?
07-17-2020 08:58 - edited 05-06-2024 06:05
Hi there @Jiji20, welcome to the Community Forums. I'm sorry to hear that your Versa's screen won't turn on. Thanks for the steps you've tried so far in order to fix it, I'll be glad to help you with this.
If the suggestions don't work and your watch doesn't vibrate when you connect it to the charger, it may be that the battery of your Fitbit is not charging properly and therefore it does not turn on. Said that, I recommend doing the following:
Best Answer07-17-2020 08:58 - edited 05-06-2024 06:05
