12-04-2020
12:59
14:02
12-04-2020
12:59
14:02
My Versa has stopped working. I charged it night before and yesterday it was dead. This is the 3rd watch I have had, its been replaced before
I have tried all resets etc but it is completely dead
Moderator Edit: Personal info removed
12-04-2020 14:09
12-04-2020 14:09
Hi there @PTAN1, welcome to the Community Forums.We acknowledge the limitation we have on our part particularly on what you have experienced. We‘re taking into consideration your comments and sentiments with regards to our products and services. Thanks for troubleshooting your Versa prior to posting here.
When you performed the restart on your watch, did you feel a vibration? If you didn't, please try the steps below:
Looking forward to your response.
Best Answer12-04-2020 14:09
12-04-2020 14:09
Best Answer12-05-2020 03:20
12-05-2020 03:20
Hi, I have tried all of the above, fitbit is completely dead.... Won't come on, tried several USB connections, tried holding down buttons... Nothing. Was purchased is July 2018, so does that mean out of warranty. This is the 3rd replacement I have had, cost me £200 so would expect it to last much longer...
Best Answer12-05-2020 04:11 - edited 08-31-2023 10:36
Hi there @PTAN1, I appreciate you had followed the tips and recommendations provided above. I understand where you're coming from, thanks for your feedback as it helps us to keep improving.
Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual.
