08-26-2021
03:59
05:12
08-26-2021
03:59
05:12
I have had my Versa 2 for approx 2 years. On and off I have had issues with it not syncing. In the past i have always been able to repair and fix.
This time my Fitbit app can't locate my versa. My phone finds it as an available device, but the App won't locate, the search just times out.
I am running my Samsung S10+ on Andriod 11. So meets compatibility.
I have restarted and factory/hard reset my versa.I have uninstalled the app twice.
Please help
08-26-2021 05:13 - edited 10-25-2023 17:12
Hi there, @Jessika81. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out and for the details provided in your post.
Please note that the difficulty you are having to set up your Versa usually happens when you perform a factory reset without first unpairing the watch. In order to solve this issue, I'd recommend trying the steps below:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Best Answer08-26-2021 05:13 - edited 10-25-2023 17:12
