Versa won't connect to my iPhone 13Pro anymore
ANSWERED
My Versa lost connection with my Iphone13Pro. I tried to reconnect it in every possible way but I failed. My Iphone finds my Versa, asks for a code, my Versa gives a code but my Iphone says that the code is incorrect! This happened multiple times. Does anybody know what to do?
1 BEST ANSWER
Accepted Solutions
Hi there, @mesilla. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out.
In addition to the steps you've done, please try the following in the order listed:
  • Unpair your Versa from your phone's Bluetooth and Fitbit app.
  • Unpair other Bluetooth devices that you may also have paired to your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off other Bluetooth connections when not in use. This can help to prevent connectivity issues or Bluetooth interference.
  • Turn on the Bluetooth on your phone.
  • Plug it into the charging cable and open the Fitbit app.
  • Set up your Versa.
  • If there is no connection, restart your Versa.
  • Once your Versa is paired and syncing, please proceed to set up your other Bluetooth devices to your phone again.
With the steps above, what I want you to do is to pair your Versa first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
1 REPLY 1
