03-30-2021
20:16
12:46
03-30-2021
20:16
12:46
Hi,
I recently replaced my phone from an iPhone 7 to a 12 and can't seem to get the Versa to connect so that I can sync.
I've been able to connect it to an iPad mini and the iPhone 7, but not the 12. On the iPad mini, there's a pop-up message comes up while I'm in the app asking if I want to pair the Versa with the device and I click "pair" and that allows it to show up under my Bluetooth settings. On the iPhone 12, it instead says that the Versa and iPhone need to be paired when I click into the device settings on the app and when I click on "set up" (not pair), there is a progress wheel that spins where the arrow is on the notification button, and nothing happens.
I've restarted the phone, reinstalled the app and restarted the device multiple times. Not sure what else to try!
04-01-2021 06:06 - edited 04-01-2021 12:47
Hi there, @mrb370. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out.
It seems that your watch cannot properly connect to your new iPhone 12 since you haven't yet forgotten the connection between your watch and the iPhone 7's Bluetooth which would explain the connectivity issues you're running into. With that said, try the steps below:
Hope that helps.
Hope that helps.
04-01-2021 12:15
04-01-2021 12:15
Thanks so much! This definitely helped.
Best Answer04-01-2021 12:49
04-01-2021 12:49
@mrb370 Awesome! I'm glad to hear the steps provided above did the trick. 😉
I'd like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
Best Answer06-01-2021 17:47
06-01-2021 17:47
I have restarted my Fitbit several times as well as my iPhone, still will not sync! I’ve tried everything!! Please help
Best Answer06-03-2021 04:16 - edited 04-07-2024 06:32
@Misdy2466 Thanks for stopping by in the Community Forums and trying to troubleshoot your Versa 3 before reaching out.
I've seen you contacted our Support Team after posting here and they've already helped you with this matter. If you have any further questions, please feel free to update your support case so they can continue assisting you.
