08-09-2022
13:30
15:34
08-09-2022
13:30
15:34
My versa 2 has all of a sudden stopped connecting to my phone, Bluetooth and WiFi aren’t being picked up! It is also loosing time
08-09-2022 15:39
08-09-2022 15:39
Hi there, @SammieRose. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa.
If you haven't done so yet, please try removing the Bluetooth connection between your phone and your Fitbit device:
*On your phone, tap Settings > Bluetooth > the information icon next to the name of your Fitbit device > Forget This Device.
*Open the Fitbit app and set up the connection again. You should receive a message asking you to allow your Fitbit device to pair with your phone. Tap Pair to approve the request.
Sync your Versa automatically when you open the Fitbit app or manually by tapping your profile picture > your device tile > Sync Now.
If the issue persists, see Why won't my Fitbit device sync?
Hope that helps.
08-10-2022 02:24
08-10-2022 02:24
I’m having the same issue
08-10-2022 05:08 - edited 11-20-2023 15:31
Hi there, @bubblesbec. Thanks for stopping by in the Community Forums.
If you're having the same issue, please make sure to follow the tips and recommendations I've shared in this post.
See you around.
08-10-2022 13:06
08-10-2022 13:06
I'm having the same thing. I've tried disconnecting the device from the app and starting fresh but it's not finding it. It's charging, I have WiFi signal and nothing else connected by Bluetooth.
08-10-2022 14:54
08-10-2022 14:54
I'm having the same issue haven't been able to sync since July I've tried all of your recommendations
08-12-2022 14:01
08-12-2022 14:01
After finally getting it to connect, by the morning it 4 hours behind. It's losing time so fast now that it's just junk.
08-14-2022 04:17 - edited 08-14-2022 04:22
Unconnected Bluetooth and reconnected. Took about 10 secs andIT WORKS! Thank you!
