11-02-2020
03:15
07:21
11-02-2020
03:15
07:21
I have never been able to get texts-one of the reasons I got my versa was to receive texts! It doesn’t want to sync now, and when it does, it takes forever, and it won’t connect to my wifi, and it will not do the update, because it can’t find it!!! I am really disappointed with it—maybe I should have gotten an apple?
11-03-2020 07:41
11-03-2020 07:41
Hi there @JillW00, welcome to the Community Forums. I'm sorry to hear about the connectivity issues you've been between your Versa and your mobile phone, I understand why you're feeling disappointed. I'll be glad to help you.
Make sure that your Wi-Fi network is working correctly and that your network type is compatible with your watch. Then move on to the troubleshooting steps if needed. For more information, see: Why won't my Fitbit watch connect to Wi-Fi?
Also, please know Fitbit products are compatible with most devices that have the following operating systems: Apple iOS 12.2 or higher and Android OS 7.0 or higher. For the latest list of devices that support the Fitbit app for Android, see Which phones and tablets can I use with my Fitbit watch or tracker?
Please note if you found out that your phone isn't a fully supported device, this will affect how your Versa connects and works with the Fitbit app. While there isn't a guarantee that it'll always work, let's try the following steps to reconnect your device:
If the issue persists after following the steps above, I was wondering if you have other apps running on the background when this happens? If you've not done so, I'd recommend to uninstall the Fitbit app, and reinstall it again.
For more information about syncing and notifications issues, see: Why won't my Fitbit device sync? and Why are notifications delayed or missing?
Let me know how it goes.
Best Answer11-03-2020 07:41
11-03-2020 07:41
