05-13-2018 12:12
05-13-2018 12:12
Hello,
First time Fitbit Versa user here. Just got my watch and have tried several times to connect it with my Pixel 2XL (currently running the Android P Beta OS), but every time I connect the Versa to the watch, nothing happens and I get back to the menu where it asks to add new device.
Please help!
I have tried to uninstall-install several times, as well as restarting the cellphone, and still no luck!
05-16-2018 10:22
05-16-2018 10:22
All of you who facing this problem has to downgrade your Android P to 8.1 or to the latest version. I had the same issue, android p caused the problem. I have a pixel 2 xl and after the downgrade my versa started to work as it should
05-13-2018 12:38
05-13-2018 12:38
Same exact issue here.....I finally just reverted back to Oreo. I loved P, but had a few too many issues with different apps to continue using it. As soon as I switched back to Oreo, the connection issue went away.
Best Answer05-13-2018 12:43
05-13-2018 12:43
05-13-2018 18:35
05-13-2018 18:35
same issue 😞 hope i dont need to revert to oreo.
Best Answer05-14-2018 18:58
05-14-2018 18:58
I also have the same issue =(
Best Answer05-16-2018 10:22
05-16-2018 10:22
05-16-2018 11:04
05-16-2018 11:04
I have a Pixel 2 XL running Android P Beta, and my Versa and Fitbit app work perfectly!
Note: I installed the Fitbit app and set up the Versa while I was still running Oreo last month.
