07-24-2018
17:47
09:50
HeydyF
07-24-2018
17:47
09:50
HeydyF
I downloaded and paired my jabra bluetooth earbuds to my versa a week ago and worked great. Now my versa sees my earbuds but wont pair with them. Please help!
Best Answer07-25-2018 10:15
07-25-2018 10:15
@mas0241 Welcome! It's nice to have you on board! Sorry to hear about your Versa not pairing with your Jabra earbuds. I suggest you make sure the earbuds are fully charged and restart your Versa by doing the following:
1.- Press and hold the back (left) and bottom buttons until you see the Fitbit logo on the screen. This should take less than 10 seconds.
2.- Let go of the buttons.
3.- If your Fitbit watch doesn't work normally, use the instructions in How do I turn off my Fitbit device? to turn your watch off and on again.
Also if you paired your earbuds with your phone delete them from the bluetooth list.
Let me know how it goes!
Best Answer07-25-2018 10:19
07-25-2018 10:19
Hey @mas0241, welcome to the Fitbit forums! If your Versa and your Jabra Bluetooth earbuds are no longer connecting, I suggest you to try the following:
- Re pair your headphones again with your Versa
You can also take a look at the information in this help article: How do I connect Bluetooth audio devices to my Fitbit watch?
Best Answer07-25-2018 18:27
07-25-2018 18:27
Best Answer07-27-2018 06:12
07-27-2018 06:12
Hey @AlvaroFitbit, sounds great that the instructions that I posted above, helped you out to connect your Jabra earbuds with your Versa. 😉 Thanks for the update!
If you have further questions or comments, let me know!
Best Answer03-12-2019 21:43
03-12-2019 21:43
I'm having the same problem with my X4T ear buds. They worked fine with the Versa on Sunday and on Tuesday they had lost the firing and won't re-pair despite restarting the Versa and turning on and off the ear buds multiple times. The Versa just stays in pairing mode forever. The buds eventually turn off, the Versa so far doesn't, just spins.
Best Answer03-23-2019 18:22
03-23-2019 18:22
@AnnaBR I hope you're doing well!
Sorry to hear that your earbuds aren't working with your Versa. Have you tried the suggestions in my previous post? Specially removing the earbuds from your phone to clear any other connection. A final solution could be a Factory Reset on your Versa and see if this helps resolve the issue but remember that you will need to set up your Versa again on your account.
Keep me posted.
Best Answer03-24-2019 11:09
03-24-2019 11:09
Yes, @AlvaroFitbit, I have tried the above mentioned steps several times. Factory reset sounds like a pain, but I will try it when I have some free time.
Thanks,
Ann
Best Answer04-18-2019 10:21
04-18-2019 10:21
Hi there , I just following your conversation cause im having same problem ,cant pair my versa to jabra ,did exactly what you suggested turned off and on but still cant pair them and before had the same problem with my samsung earbuds thats why bought this jabra today .....
