05-13-2018
12:04
11:22
MarcoGFitbit
05-13-2018
12:04
11:22
MarcoGFitbit
I can't get my Versa to recognize my Jaybird x3 wireless earbuds. It finds my TV but not my earbuds! What am I doing wrong?
05-15-2018 11:23
05-15-2018 11:23
Hello @Sparky333, thanks for joining the Fitbit Community, it's great to have you on board.
Thanks for bringing this to my attention. Please note that the Versa should not have difficulties pairing with any kind of Bluetooth headset but if yours is stuck during the pairing process I would like to suggest you the following:
After checking these points, try to connect your headset again:
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
05-15-2018 11:23
05-15-2018 11:23
05-20-2018 17:15
05-20-2018 17:15
Sparky 333, I had the same problem.
In order to connect your Jaybird X3 to fitbit versa you need first to put them in PAIRING mode. To do so:
1) Turn the buds off
2)Then Press and hold the power button for more than 4 seconds until you see alternating red/green lights.
Now from your watch go on Setting/Bluetooth and click + Audio Device. It will search then pair and then you press connect and off you go.
Hope it helps.
05-21-2018 05:18
05-21-2018 05:18
Hello @DavideP75, thanks for joining the conversation, it's great to have you on board the Fitbit Community.
I appreciate you have taken the time to share your experience and the steps you took in order to pair your Bluetooth headset, I'm sure they will be very helpful for members of the Community facing the same situation.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
05-21-2018 06:31
05-21-2018 06:31
Thank you so much! It worked!
05-21-2018 11:37
05-21-2018 11:56
05-22-2018 05:25
05-22-2018 05:25
Hello @Sparky333 and @DavideP75, I hope you're doing well, thanks for taking the time to reply.
@Sparky333, I'm very glad your issue has now been resolved, at this moment I would like to welcome you to our Discussion boards, where you can find tips and inspiration from other members of the Community to keep you motivated.
Thanks again for letting me know the outcome of your issue, if there's anything else I can do for you, please feel free to reply.
08-30-2018 05:45
08-30-2018 05:45
Ive got versa and jaybird run
this post worked perfect
thanks man
01-08-2019 16:59
01-08-2019 16:59
Thanks for the advice--finally got it to pair. However, my Versa doesn't seem to have ANY range, I wear it on my left arm and it cuts out really badly. I even tried to wear it on my right, but it will only work continuously if I hold the watch next to the earbuds. Not handy at all. Is there something I can do about this?
01-10-2019 18:38
01-10-2019 18:38
I have restarted the watch, put my headphones in pairing mode, turned off my phone, and my Fitbit still won't see the headphones. Help!
02-18-2019 08:29
02-18-2019 08:29
Did anything work for you? I also have an X3 headset and it won't pair with my Versa.
10-23-2019 07:41
10-23-2019 07:41
thank you was not until I scrolled down to your advice that it worked.
01-09-2020 15:52
01-09-2020 15:52
How I can connect same speaker Jaybird x
X3 to Fitbit versa 2? I've trying several times, it shows other devices but the Jaybird.
01-09-2020 22:07
01-09-2020 22:07
Finally I found the solution myself, by reading the Jaybird X3 set up instructions, and got the connection to my Versa 2:
1- if you are not able to see your Jaybird speaker device from your SW
2- switch off your Jaybird X3
3- Then switch on again and VERY Important: hold the switch On button till the green lights and a little beep sound
4- you magically be able to discover your device listed
5- select it and that's it!!!
02-27-2020 10:01
02-27-2020 10:01
Marco G.
Thank you for your advice but I have tried these steps multiple times ensuring all my other devices are turned off and my Versa2 will still not recognized by wireless earbuds to pair. Any other suggestions?
Thanks,
Brenda
05-25-2020 19:57
05-25-2020 19:57
Thanks a lot! this helps and works so well after been trying to pair device all night 🙂
