Versa won't display the correct time
Why wont my time on my Fitbit sync with my phone? I have tried restarting it and everything.
2 REPLIES 2
Hi, sounds like you're using a Third Party Clock Face. If yes, change it to one developed by Fitbit itself and restart your Versa and the problem should be solved.
@Mirandab44 Welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since the time on your phone won't reflect on your watch. By the way, thank you for troubleshooting this issue before contacting our forums.
I'd like to know if your Versa is actually syncing properly. Please try follow the troubleshooting steps that are listed in this help article, which are for syncing issues. After syncing your Versa, check out if the time is correct.
Keep me posted on the outcome! Smiley Happy
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
