Versa won't hold a charge after swimming
Hi! I have had my Versa for a couple of years now and have never had this issue. I went swimming over spring break and now my watch keeps dying on me. I will charge it right before going to bed and by morning it is dead. I bought this watch specifically so I can swim with it on. Please help me fix this. Thank you!
1 REPLY 1
It is probable that the watch has water in it. You can check by inspecting the windows on the back with a magnifying glass to look for beads of condensation.
This was an issue on older Versas, which don't like hot water and become non waterproof.
It may also be a fault with a watch face or the watch itself. Try restarting it [if that hasn't automatically happened by going flat]
If that fails try Fitbit Support. They may be able to help you.
