06-26-2020
11:04
06:49
06-26-2020
11:04
06:49
Hi. My Versa didn't hold a charge and now it won't turn on. I tried doing a restart but nothing happened.
06-27-2020 06:52 - edited 01-27-2024 12:43
Hi there @keeper21, welcome to the Community Forums. Thanks for the details provided in your post about your Versa not turning on. I appreciate you've taken the time to restart your watch prior to posting here.
As per the description of your post it seems that the battery on your watch may not be charging properly and therefore does not turn on. I recommend that you follow these steps (or please confirm that you've followed them as described below):
Keep me posted on the outcome.
06-27-2020 10:43
06-27-2020 10:43
Hi. I bought a new charger and it didn't start. I tried restarting it and nothing happened. What else can I try?
Thanks
06-27-2020 11:01 - edited 10-11-2023 18:21
Hi there @keeper21, I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
