08-01-2019
05:57
05:18
JuanJoFitbit
08-01-2019
05:57
05:18
JuanJoFitbit
I have had my versa since late December, no issues with battery holding a charge until this weekend. I have to put it on charge about twice a day now. Any reason why it isn't holding a charge? Nothing has changed on the interface.
08-03-2019 05:18
08-03-2019 05:18
@Tctrish86 welcome to our Fitbit Community! By the way, I'm sorry for the late response. However, I'd like to follow up on the battery draining issues that your Fitbit Versa is experiencing.
Please check out and try the tips that are listed in this help article in order to improve the battery life of your Versa. After this, monitor the battery behavior of your watch and see if it lasts longer.
Keep me posted on the outcome! ![]()
Best Answer08-08-2019 12:56
08-08-2019 12:56
Thanks but none of that helps, now it won't charge to 100% and I took it off of charge at 440am after being on charge for over 2 hours only charging to 99% and here it is now almost 4pm the same day, less than 12 hours later and the battery is down to 23%. Very little to no activity as i have been at my daytime desk job..
Best Answer08-12-2019 10:09
08-12-2019 10:09
@Tctrish86 I'm sorry for the late reply. However, since the battery of your Versa is still draining fast, I'll send your case to our Support team so they can investigate further and provide a solution. You will receive an email from them soon.
Let me know if you have any questions! ![]()
Best Answer03-16-2020 05:29
03-16-2020 05:29
I also am having the exact same problem. How was your situation resolved?
Best Answer04-22-2020 08:34
04-22-2020 08:34
Hi @star126, due to the recent events, I apologize for the delayed response. However, let me welcome you to our Fitbit Community.
I would like to follow up and would like to know if your Versa is still experiencing battery draining issues.
In the meantime, please follow the tips that are listed in this help article. After this, monitor your watch for the next 24 hours and see if the issue gets fixed.
Keep me posted on the outcome.
Best Answer05-04-2020 14:02
05-04-2020 14:02
I have had my fitbit Versa for about a year and a half. All of a sudden last week, it just died. I tried restarting it several times, and finally the fifth time I restarted it, it worked. I had it charged all day, and it was 100%. I wore it for about 3 hours, while watching tv, and it died. It did not hold a charge. I have charged it 4 time since, and it will be 100%, and after 2 hours, 52%. I don't want to have to buy a new one, but I miss wearing it!
Best Answer06-26-2020 03:43
06-26-2020 03:43
Same problem here. It used to stay charged for 4 or 5 days and all of a sudden it won't hold a charge for 12 hours and I never changed the settings which could have caused a battery drain. I tried the "help" options but it made no difference. I purchased the watch in December and it's not even usable now.
Best Answer06-26-2020 04:21
06-26-2020 04:21
My first Versa did this and would no longer sync with anything (tried android, windows, iPhone, etc). I was able to exchange it under the extended warranty my mom bought on it (it was a Christmas gift in 2018). My replacement Versa is now doing the exact same thing, and I've only had it since March.
Basically, the last firmware and/or app update broke a lot of Fitbit devices, and Fitbit keeps saying they're working on it, or it's your fault the device doesn't work correctly. So either try to get a replacement if you can, or switch to an entirely different company if you don't want to worry about constantly replacing your Fitbit.
Best Answer10-02-2020 12:21
10-02-2020 12:21
I’ve had my versa lite since Christmas 2019 and I’ve been having the same issue for the past few months. I don’t have any notifications coming up on my Fitbit, brightness set to dim and will only turn on when I press the button. I charge it to 100% and within 36 hours it’s at <10%. It’s frustrating because it was a Christmas gift and I’ve only had it 9 months.
