10-21-2019
09:56
07:13
JuanJoFitbit
10-21-2019
09:56
07:13
JuanJoFitbit
My versa doesn't hold a charge for 24 hours. It used to hold a charge for a week. Can you help?
10-21-2019 10:24
10-21-2019 10:24
Hi @Hefner , try restarting your Versa three times with the two buttons method. When this does not solve your battery problem, call Customer Support and ask a battery test. Regards kuzibri
10-21-2019 11:11
10-21-2019 11:11
Best Answer10-21-2019 11:16
10-21-2019 11:16
Hi, press and hold the left and right lower buttons of your Versa together untill you see the Fitbit logo and release the buttons. Regards kuzibri
10-22-2019 07:12
10-22-2019 07:12
@Hefner welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since the battery is not lasting as long as it should.
In addition to the restart process that @SunsetRunner shared, I'd like you to try the tips that are listed in this help article. After trying these tips, monitor your watch and see if the battery lasts longer.
Keep me posted on the outcome.
10-22-2019 07:50
10-22-2019 07:50
Best Answer10-22-2019 08:14
10-22-2019 08:14
Hi, time to call Customer support, see my fist post. Regards kuzibri
Best Answer10-23-2019 07:28
10-23-2019 07:28
@Hefner thank you for getting back and trying the recommended tips. I was able to get in touch with our Support team and was told that you contacted them as @SunsetRunner advised.
Please check out your email account since they provided some instructions in order to follow up on the battery issues that your watch is experiencing.
I'll be around if any question arises.
10-23-2019 09:26
10-23-2019 09:26
