01-23-2024
15:02
06:42
01-23-2024
15:02
06:42
Hello,
I have a versa 2 that I am upgrading. In this process, I factory resetted the device and now cannot be paired again. I have done the following:
reset device again
Reset phone
unpaired bluetooth connection
Turned on/off bluetooth on phone
uninstalled/Reinstalled app
Forced closed app
When setting up, I choose the Versa2, then as it just searched, then will not pair. I keep getting message to turn device on (Which it is). Any other ideas?
01-24-2024 06:51
01-24-2024 06:51
Hi there, @kgowen4444. Welcome to the Fitbit Community Forums. It's sad to hear that your Fitbit device is still not pairing despite the steps you've done so far. I will do my best to help you to sort this out!
As a first approach, I'd recommend connecting your Fitbit device to the charger before you begin the setup process. Even during the setup process I still suggest leaving the Fitbit device connected.
Nonetheless, while reading the last part of your post, I was wondering if maybe you don't have the Versa 2 but other Versa smartwatch? Have you tried selecting Versa, Versa Lite, or Versa 3 instead of Versa 2? If you haven't done so yet, give it a shot and see if the process goes through.
If you continue having difficulties to pair your Fitbit device after trying the above, please see Why can't I set up my Fitbit device?
Best Answer01-24-2024 12:33
01-24-2024 12:33
I have the exact same problem and have also tried the same fixes. Very frustrating
