10-05-2020
19:47
13:12
10-05-2020
19:47
13:12
Hello i did a factory reset after that my versa 1 shut off bluetooth ,now i'm not able to pair with it for configuration
10-06-2020 14:41 - edited 04-06-2024 10:07
Hi there @Heike79, welcome on board. Thanks for the details provided in your post and for following the tips and recommendations I've shared in my previous post. I understand how important is to you to get your watch back in business.
Since none of the steps have worked so far and you've already made sure that your watch is no longer connected on your phone's Bluetooth settings, I'd recommend to performing a factory reset by following the steps below:
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
10-06-2020 13:14
10-06-2020 13:14
Hi there @remi900, welcome to the Community Forums. I'm sorry to hear that your Versa isn't pairing to your Fitbit account after performing a factory reset. I'll be glad to help you with this.
Please note that the difficulty you are having to set up your Versa usually happens when you perform a factory reset without first unpairing the watch. In order to solve this issue, I'd recommend trying the steps below:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Let me know if you need further help, I'll be around.
10-06-2020 14:23
10-06-2020 14:23
I have the same issue and followed all the steps. Versa is not responding. It won't connect either to my phone or laptop. My versa 2 is not even 1 year old and shouldn't have that problem. I need my versa to work again. My laptop will find my versa but can't get to sync.
