07-29-2019 23:29
07-29-2019 23:29
Hi, there!
I've been owning a Versa for 3 months now and this week it started to make problems. I can't pair it with my phone (which has Android 6.0) or sync it. It doesn't work either on the Fitbit app or in the Bluetooth settings. I tried to close them both and reopen them again and it didn't work. I also tried to delete the Fitbit app and reinstall it again but I got the same issue. Any suggestions?
07-30-2019 00:41
07-30-2019 00:41
Hi @Badmintongirl15 What phone are you using (make and model)?
Try all the suggestions in THIS Help Article on syncing problems
Helen | Western Australia
07-31-2019 02:57
07-31-2019 02:57
Hi @NellyG! I have a Huawei P20 Pro. Thanks for the advice. I will see if it will work.
Best Answer07-31-2019 04:52
07-31-2019 04:52
That phone should work, so go through the article.
