12-02-2021
04:12
06:44
12-02-2021
04:12
06:44
I have not been able to sync my Versa to my phone since last Sunday. I have tried resetting the device, uninstall and reinstall the app on the phone. No I can't even set it up as a new device. The phone is not pairing the device at all.
Someone please help.
Thank you.
12-02-2021 05:24
12-02-2021 05:24
Hi @sssankar - try restarting the phone and the watch again - also see Sync setup and troubleshooting
12-02-2021 06:46 - edited 02-14-2024 03:29
Hi there, @sssankar. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Versa from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa.
12-02-2021 07:14
12-02-2021 07:14
Thank you both for the warm welcome and your replies.
I have managed to fix the problem.
I added another device, Versa Lite to my phone (XiaoMi 9T Pro). The Fitbit app was able to pair it with the phone. Awhile later I tried to add my own device, Versa and I was able to pair it with the phone now.
I not sure what was the reason for this but it works now.
Once again thank for the replies.
