Versa won't pair with my phone anymore
My versa not working. First it was the time was hours behind then stuck on black screen with logo. I diconnected/unpaired from my phone to reset it. Now it will not pair with my phone now. Nothing working. Screen still has logo sometimes
7 REPLIES 7
Hi there, @kerryannglass71. Thanks for stopping by in the Fitbit Community Forums and trying to troubleshoot the issue with your Versa before reaching out.
In addition to what you've done, please try the steps below (while your Fitbit device is still connected to the charging cable and even if some of these steps you've done already, just follow them in the order listed):
  • Unpair your Versa from your phone's Bluetooth and Fitbit app.
  • Unpair other Bluetooth devices that you may also have paired to your phone's Bluetooth settings.
  • Force quit the Fitbit app.
  • Turn off other Bluetooth connections when not in use. This can help to prevent connectivity issues or Bluetooth interference.
  • Turn on the Bluetooth on your phone.
  • Plug it into the charging cable and open the Fitbit app.
  • Set up your Versa.
  • If there is no connection, restart your Versa.
  • Once your Versa is paired and syncing, please proceed to set up your other Bluetooth devices to your phone again.
With the steps above, what I want you to do is to pair your Versa first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
This did not work. Bluetooth cannot find my versa
all the attempts suggested.  mine started after updating to IOS 16.6.  not able to discover the Versa at all in Bluetooth.  tried iPad also (not updated) but it didn't work either.  tried changing to the google sign-in and still nothing.  Out of ideas and all suggestions provided have not worked.
This didn’t work for me either. Could it be IOS 16.6? Mine tries to sync and then stops. Steps show and then revert to zero.
No Bluetooth is finding my versa at all.
Weird, but now I’m synced! My sleep score for last night even showed up!--
Mary Lorentz
I am also having this problem and have tried everything you suggested. Mine also is losing time. It is not 10 minutes slow and I have tried changing the time zone. Will this ever be fixed?
