07-26-2022
		15:21
		15:32
		07-26-2022
		15:21
		15:32
So about a week ago my Versa 1 ( first generation 2018) battery died- I charged it and was going to sync since the time was when it had died. Long story short- I have rebooted phone, app and watch! I have done everything it says to do! It won’t sync to Bluetooth and when it did (one day) the time was still wrong and then I went to re sync it didn’t even show on my Bluetooth- my tracker is due for update but I don’t have WiFi! But the time watch itself was working just wrong time but not sync to phone! Well now it won’t stay on after charging all night numerous times! It will be on for a hour (guessing) when I look it’s off and just shows the blue Fitbit logo might turn on might not! Help is needed - I have NEVER had a issue like this before !
07-26-2022 15:34 - edited 04-02-2024 11:29
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
Hi there, @Spark86. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out. I understand where your concern is coming from.
Since you've mentioned that your Versa is stuck on the Fitbit Logo, please try the steps below:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Was my post helpful? Give it a thumbs up to show your appreciation!  Of course, if this was the answer you were looking for, don't forget to make it the Best Answer! Als...
 Best Answer07-28-2022 14:30
07-28-2022 14:30
So not sure if my previous message went through but I’ve done all the above- nothing now just has the Fitbit logo won’t charge -
 Best Answer07-28-2022 20:46
07-28-2022 20:46
I have a versa 2 and it's not responding to anything can't even turn it off
 Best Answer07-29-2022 09:09
07-29-2022 09:09
I've got same issue. Noticed I wasn't getting my messages on my Fitbit anymore, didn't care. But went to charge and it won't charge. Cleaned contacts, nothing works. Went through above steps to unpair, restart, nothing works. This is only 2 years old and it's ridiculous.
 Best Answer08-01-2022 14:59
08-01-2022 14:59
I have the Versa 1 (when it first came out) so mine is almost 4 years old! But it’s in great condition not scratched up worked great until 2 weeks ago! I’ve done everything ! And now I can’t get it to stay charged it will charge time is either 4-12 hours off then goes to correct time when I was linked to work! I even tried on my sons iPad ! It tracked my steps not sure how tho!
08-01-2022 15:00
08-01-2022 15:00
Mine charges says 100% then after I looked at it 30 mins or hour later it’s dead like wth- if it’s a battery then how do I get a new battery. I even removed it from my app thinking I needed to reset it up well now since I can’t get it to sync to Bluetooth in my phone I can’t even get it back on my app!
 Best Answer08-01-2022 15:02
08-01-2022 15:02
I have done all the above more then once! I have even removed it from my app think t maybe a totally re setup well now I can’t get it set up it won’t sync to Bluetooth at all and battery won’t stay charge. I really wish I could get some answers ?? If it’s the battery how do I go about getting a new one ? Something would be great other then trying to the above request cause that didn’t work
08-01-2022 15:24
08-01-2022 15:24
@Spark86 this is a bug due to the latest update on the FitBit app for Android 3.64.5 and iOS 3.64. Versa 2 is having the same issue.
there currently is not an ETR for the issue, but support states to make sure app is up to date and all that.
08-01-2022 16:24
08-01-2022 16:24
Mine was versa 2. They tell me there's no fix, off warranty. Sent me a 35% off code for new one. Better than a poke in the eye but it sucks it didn't last more than 3 years. So I ordered a new one. Nothing lasts anymore. 😞
08-02-2022 07:47 - edited 08-02-2022 07:54
My versa 2 blackscreened yesterday. Wont turn on at all .It was fully charged at the time .
 Best Answer08-02-2022 08:03
08-02-2022 08:03
 Best Answer08-03-2022 21:03
08-03-2022 21:03
 Best Answer08-04-2022 11:24
08-04-2022 11:24
Same problem only to be told its out of warranty that there is nothing they can do.offered me 35% to buy another one ( having a laugh) I asked if the could send me out a charger so that I could check if maybe its just the charger but no theyvare just sorry for my inconvenience & then asked me to review with a survey ha!
 Best Answer08-05-2022 12:15
08-05-2022 12:15
