04-17-2018 09:02
04-17-2018 09:02
I'm following the steps to add my headphones, however, it searches for available bluetooth connections and then..nothing. My bluetooth connected with my phone just fine, but it wont even show up in the versa.
I have a LG 750 I think.
If someone can help, I would appreciate it. Thanks in advance!
Best Answer04-17-2018 09:28
04-17-2018 09:28
Versa just needed to be restarted. It picked up the connection after that.
04-17-2018 09:28
Best Answer12-28-2018 17:58
12-28-2018 17:58
You said reset. Did you do a Factory reset??
Cause I'm having the same problem and I've shut it off several times and have had no success. But I'm worried about doing a Factory reset.
