08-23-2022
17:57
04:13
08-23-2022
17:57
04:13
Versa not recognizing contact names anymore just tells me Unknown Caller
08-26-2022 04:16 - edited 07-14-2023 03:48
Hi there, @Jawin64. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa.
As @SunsetRunner has suggested, please confirm if you have enabled the Fitbit app permissions under Settings of your Android device. If you've done that, please try going to the phone Settings > Apps > Fitbit > Permissions and toggle off "Contacts", then restart your phone and toggle "Contacts" back on.
Also, check that your Fitbit app is up-to-date. For more information, see What's changed in the latest release of the Fitbit app? To download the latest app version, please visit the Google Play Store here.
08-25-2022 11:24
08-25-2022 11:24
Hello @Jawin64
Let’s try this..Open your Fitbit app, tap on your profile picture then scroll down and tap Versa. Now scroll down and tap notifications. (If any permission request pop open answer yes) Now while on the same page tap App notifications and check if more permissions are needed to access your calls. Sync your Versa once your finished so your Versa will accept any changes you might have made.
If the problem continues I’d suggest checking your settings again. I’m not sure if your using an Android or iOS so I post both settings here:
Android User:
iOS User:
😃 I hope this helps. Please let me know
