Versa won't show weather
ANSWERED
fitbit wont show weather
1 BEST ANSWER
Accepted Solutions
😃 I’m happy I was able to help answer your question @cambo53! Please consider marking the post that gave you the solution as “best answer”. Doing so really helps other individuals find the the solution quickly when searching the forums. I’d appreciate it and have an awesome evening.
3 REPLIES 3
Hello @cambo53
Lets make sure your settings are correct. Open the Fitbit App, tap your profile picture then scroll down and tap Versa. Now tap gallery. Next scroll down and tap weather. First tap permissions and make sure your permissions are enabled. Now return to the previous screen and tap settings and select which unit you want to be displayed. Now tap the today button at the bottom of your screen. Manually Sync your Versa by swiping downward on the page to accept any changes you just made.
😃 Please come back and let me know if this helped answer your question
Thanks for the help. That solved my problem. For some reason my Fitbit deleted the weather. Maybe because I let it run dead? But everything is good!!
Sent from my iPhone
