04-26-2018 07:13
04-26-2018 07:13
It seems my Versa is working as it should functionally however it wont stay connected to Bluetooth long enough to fully sync, update apps, receive notifications, etc... In the fitbit app under my account it will say "looking..." for a while then "connected..." for a second, then "syncing..." for a second then just go back to "looking...". So i went to my iPhone Bluetooth settings and can see that it connects for a second or two then just disappears, then connects and disappears and continues the cycle. Anyone else having this specific problem? Any suggestions to fix it? I've restarted the app, uninstalled it, reinstalled it, turned my bluetooth on and off, restarted my phone, restarted the Versa. Nothing seems to work.
04-27-2018 08:25
04-27-2018 08:25
Hey @Jasonp5, let me give you a warm welcome to the Community! I appreciate the time that you have taken to try to fix this issue. Beside that, there are some other tips in this help article: Why won't my Fitbit device sync, that I'd like you to try to sync your Fitbit Versa with your iPhone.
In addition, I'd like you to try to sync with a computer, or by any chance you have it, with another compatible device.
If the inconvenience persist, let me know!
04-27-2018 09:10
04-27-2018 09:10
When I contacted tech support yesterday, I was asked to try connecting it with another Bluetooth device. So we tried my iPad. Didn’t work. Tech support then told me to return my Versa to Fitbit for a replacement. Since the rose gold/peach is not in stock, I was told I need to wait 2-3 weeks. So whatever it is, this is a huge problem that remains unresolved.
04-27-2018 09:11
04-27-2018 09:11
Yes mine is the exact same problem!
04-28-2018 10:07
04-28-2018 10:07
I’m having the EXACT same issue. Very disappointing. Thanks the info. I have spent days trying to fix.
04-28-2018 14:58
04-28-2018 14:58
I have the exact same issue.
I have connect to a live chat for support 3 TIMES.
I have only had my VERSA for 4 days.
This is very disappointing. I will be returning it and continuing to use my blaze.
04-29-2018 06:48
04-29-2018 06:48
Having the same problem. Have had mine for going on two weeks now and this just started yesterday. It doesn’t sync throughout the day, even though that setting is on and I can’t get to to connect at all this morning. The looking, to syncing, then right back to looking. Seriously frustrating. Took a lot to make the decision to invest this amount of money into a fitness tracker!
04-29-2018 09:47
04-29-2018 09:47
I am having the same problem. It isnt syncing on my phone. I have tried all the troubleshooting multiple times. I brought mine on 4/16. It worked fine for about a week and a half; I've been having bluetooth connection problems since Tuesday. It finally synced on Friday then stopped and I got it to sync just a few minutes ago and wont sync again. I love my fitbit, I have had several in the last 3+ years. Im just very frustrated like the rest of us.
04-29-2018 10:14
04-29-2018 10:14
I am having the exact same problem. Versa is not connecting to my iPhone or iPad. I just upgraded from a Blaze which I had for less than a month as it was not syncing and the time would update correctly. I started using Fitbits in 2014 and I have gone through at least 12 for various reasons.
04-30-2018 13:13
04-30-2018 13:13
I don't know if its something I did or not, but this morning I reset my fitbit, took everything off of my Bluetooth settings, turned off my phone (not a restart) and then turned it back on, and then I turned on my hotspot and ever since it has been syncing. I just thought I'd share.
05-19-2018 11:49
05-19-2018 11:49
I’m really tired of doing all your “fixes” on a daily basis. Mine won’t connect via Bluetooth on iPhone or iPad. Nor will it connect through WiFi. So very disappointed. Right now my Versa shows 7220 steps and 979 calories. Sorry I wasted money on upgrading to Versa from charge2
05-19-2018 16:19
05-19-2018 16:19
I have same problem with my Versa LE. The device keep loosing the connection with my SGS8. Not reliable at all. Horrible!
The only way I can get going is turn off the Versaa and turn back On, and cleat the cache on the phone!
Interesting though, my Charger 2, I don't have same problem for more then one year, with same phone.
It's a shame they cannot solve this problem! I am very disappointed with the product!
05-19-2018 17:35
05-19-2018 17:35
Same. I've spent entirely too much time on my Versa. Wifi connecting/disconnecting. . Same with Bluetooth. Which means nothing works.
My Charge 2 works perfectly almost all the time Same phone Samsung G8
Will likely return.
05-23-2018 18:17
05-23-2018 18:17
I was having the same issue, however I deleted the versa from my blue tooth, deleted app and reinstalled several times and cannot get my I phone to connect. Very frustrating. Any ideas?
05-24-2018 02:57 - edited 05-24-2018 02:57
I had the same thing happen as Jujube289. Thy had me connect the versa to a different device, reset it multiple times, even did a factory reset. Nothing, still would not sync or would only sync for a few hours. They had me send it back for replacement, still have not received the replacement yet. Been holding off reviewing this device until I get a working model. Giving Fitbit one last shot here before returning it to the store for a refund. (crossing fingers).
05-28-2018 19:41
05-28-2018 19:41
Okay, so I see that you have an iPhone, but I was having the exact same problem with my versa. I have a galaxy s8, but my syncing problem stopped when I turned my phones visibility on. Hope this helps the iPhone community!
05-28-2018 22:17
05-28-2018 22:17
05-29-2018 08:11
05-29-2018 08:11
I bought also a versa, as I wanted to move up from my Alta HR. But I had to got back to it as after the installation first time, It keeps loosing the connection to bluetooth and reconnecting (to my Moto X play) without getting to sync or setting parameters set in the app. Very disappointing after having no problems with my Alta HR. I now had to move back to that device, waiting to improvements by Fitbit in the firmware.
06-01-2018 21:00
06-01-2018 21:00
Same exact here. I'm a long time fitbit user but will be changing to another brand after my issues with the versa.
06-01-2018 21:20 - edited 12-30-2018 20:32
Same here... Unfortunately. Nothing helps for the long run. My phone is discoverable. I restarted both Versa and my Droid so many times, cleared cache, uninstalled and reinstalled etc. To no avail... Very disappointed.
ETA: Since June, I have discovered how to make my Versa behave:
