04-26-2018 07:13
04-26-2018 07:13
It seems my Versa is working as it should functionally however it wont stay connected to Bluetooth long enough to fully sync, update apps, receive notifications, etc... In the fitbit app under my account it will say "looking..." for a while then "connected..." for a second, then "syncing..." for a second then just go back to "looking...". So i went to my iPhone Bluetooth settings and can see that it connects for a second or two then just disappears, then connects and disappears and continues the cycle. Anyone else having this specific problem? Any suggestions to fix it? I've restarted the app, uninstalled it, reinstalled it, turned my bluetooth on and off, restarted my phone, restarted the Versa. Nothing seems to work.
08-15-2018 11:10
08-15-2018 11:10
I have been in a conversation with fitbit on twitter since Monday about this issue. I raised it when I noticed gps was dropping its connection.
Not once have they acknowledged ed that there may be a problem even with the very large numbers of people with similar issues.
08-15-2018 13:13
08-15-2018 13:13
08-16-2018 12:36 - last edited on 10-14-2019 18:51 by LiliyaFitbit
Actually, the battery will show on the top left corner if you swipe up on
the main screen. I also have the battery showing on the watch face I chose.
Something has happened, either an update to the fitbit app or my settings,
because my versa has stayed connected to my phone for the last 5-6 weeks.
I read the threads in this post and did everything that was suggested and I
had a fitbit update, so I don't know which it was that corrected the
problem.
08-16-2018 14:14
08-16-2018 14:14
My fitbit has also stayed connected for the last few weeks too. I had a small update that came from no where maybe this is the solution? Ive not messed with any settings in the last few weeks or so.
I was thinking of seeling the versa before but now it works im quite happy
08-16-2018 14:29
08-16-2018 14:29
I changed my clock face and did a restart and I haven't had another issue with the bluetooth.
08-25-2018 14:26
08-25-2018 14:26
I just got my Versa after having my blaze for over two years and I am so disappointed. My Versa will not stay connected to my phone at all. Maybe it’s time to get the Apple Watch.
08-25-2018 14:53
08-25-2018 14:53
08-26-2018 07:20 - last edited on 10-14-2019 18:53 by LiliyaFitbit
I just called them again this morning for the 5th time and the REFUSE to refund my money since it is past the 45 may return policy! I am disputing through my credit card company. I have a worthless $300 paper weight!!
08-26-2018 09:55
08-26-2018 09:55
08-26-2018 09:56 - last edited on 10-14-2019 18:55 by LiliyaFitbit
None
08-26-2018 10:01
08-26-2018 10:01
Did you try removing g the fitbit app from Doze?
08-26-2018 10:03
08-26-2018 10:03
09-04-2018 20:32
09-04-2018 20:32
I have been facing the same issue.. my Versa won't stay connected to my phone for more than a couple of mins, and this ruins it's ability to stay connected to GPS for my runs..
Enabling the 'Always Connected' feature in the app also doesn't help..
Please suggest..
09-05-2018 02:30 - last edited on 10-14-2019 18:54 by LiliyaFitbit
Fitbit finally agreed to refund my money on the Versa. I sent it back. I couldn't justify having a $300 paper weight.
09-17-2018 19:05
09-17-2018 19:05
I have a charge 2. I got it to use gps for hikes. It suddenly was disconnecting from my iphone bluetooth. I would go to my phone bluetooth and connect and it would disconnect within a few minutes. I restarted the fitbit but it did not help. I then realized that I needed to look at settings in the app after the restart. Notifications was off so I turned it on and it asked to pair the fitbit and phone. The connection is now solid. It seems that the fitbit app needs to manage the connection between the fitbit and phone.
09-20-2018 09:26
09-20-2018 09:26
I am having the same issue. I'm so disappointed and really sorry I spent so much money on this. I have synced mine with my last Samsung Galaxy 8+, and now it's synced with my note 9, but it only syncs if I manually do it. What is the use of spending so much money on one of these if the technology is garbage? This is my first and last Fitbit product.
09-20-2018 10:25
09-20-2018 10:25
I’m having the exact same problem. Any advice??
09-20-2018 11:58
09-20-2018 11:58
09-20-2018 12:02 - last edited on 10-14-2019 18:54 by LiliyaFitbit
Yes, send it back for a refund. I had to contact a supervisor from Fitbit through Facebook and they finally agreed to refund me.
This issue is clearly on Fitbit's end. I never had this issue with the Blaze.
09-25-2018 06:13
09-25-2018 06:13
