Versa won't stay powered on
I got my Versa at Christmas. Last night, I noticed that it wasn't powered on. I went and plugged it in, and it restarted. However, it only stays on for maybe 30 seconds before it turns off again. It says that it has a 99% charge, even though it was plugged in all night. It turns on when its first plugged into the charger, but if I try to take it off the charger the screen goes black. I've tried to power it on using the buttons, but that doesn't appear to help. Anyone have tips to try?
7 REPLIES 7
@m.howard20 Welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it doesn't stay on after you unplug it from the charger. By the way, thank you for troubleshooting this issue before contacting our forums.
I'd like you to try the troubleshooting steps that are listed in this help article. This article contains the restart process but you can skip it since you already tried this process before. After those steps, please charge your Versa for 2-3 hours and see if the issue gets fixed.
Keep me posted on the outcome! 😀
JuanJo | Community Moderator
Running with music makes you happy! Share Your Story
I've been having the same issue, sort of.  The tracker is on, but the display keeps going off.  For instance when I want to check my steps per hour....I can't get the display to stay on long enough to let me see that data.   I have to continually hit the left side button to turn it back on. I've adjusted the time that the display stays on to a full minutes....still goes off after a few seconds.
@LeighAnn08 I'm sorry for the late response. However, it's great to see you in our Fitbit Community.
Regarding the display issue that your Versa was experiencing, I was able to get in touch with our Support team and was told that they assisted you via via email. Please check out your email account in order to follow up and proceed accordingly.
I'll be around if any question arises! Smiley Happy
Yes, I have to purchase a new Fitbit versa and have done so
Thanks,
Sent from my iPad
Moderator edit: removed personal info
@LeighAnn08 thank you for getting back. By the way, I'm sorry for the late response. However, I'm so glad to hear that you are back on track with a new Fitbit Versa. Thank you for posting the update here.
As a side note, I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often! Smiley Happy
I purchased my versa at the same time and am having the same issues. It’s happened before and I was able to reset it. This time no such luck. I’ve charged it for the recommended time, check the connections, and made sure the device was clean and dry. I’ve tried several times to restart it. I’ve gone to the help forums and done troubleshooting. It just won’t stay on.
I'm having same issue. Have restarted it numerous times, will charge and turn on but screen goes blank and won't come back. Stayed on long enough once to do restart from Settings menu and still having same issue.
