07-18-2020
09:51
07:46
07-18-2020
09:51
07:46
I have the org versa. I've been using it for just over a year.
Early this morning I felt it vibrating. I thought I was just touching it with my other hand while I slept. I moved my arm away from the rest of my body and it still randomly vibrated. Once awake I looked and have noticed it's also flipping through the top left hand notification (heart, steps, miles) section. It will also go to other screens randomly without being touched and flip through all kinds of things. Pressing any button doesn't seem to make it go back. It is currently going from sleep to wake mode (flashing off and on). I've power cycled it and updated the app. I dont see a software update in the app itself.
07-20-2020 07:48 - edited 06-14-2024 12:06
Hi there @Avdra, welcome to the Community Forums. Thanks for bringing this to my attention and reporting your Versa's recent behavior. Thanks for trying to fix it, I'll be glad to continue assisting you.
In order for me to better assist you with this, please confirm that you've followed the steps below as described in the help articles:
If the suggestions don't work and your watch doesn't vibrate when you connect it to the charger, it may not be having a good connection with the charger and therefore, it won't properly charge. Said that, I recommend doing the following:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Best Answer07-21-2020 10:39
07-21-2020 10:39
Worth noting after my org post....I did notice the screen may have looked discolored but want sure. I changed the watch face to as much of a white one as possible and sure enough it looks off in sections and I can't press the apps on the right hand side of the screen (just won't respond, so I can't press the settings app).
I did get it wet for the 1st time ever last week. I went kayaking (very easy, smooth river, and I was never in any water over my head). I also showered with it for the 1st time afterwards. I'm thinking possible water damage. I intentionally wouldn't get it wet bf but went against my better judgment and kept it on when I got in the river that day and assumed i was fine to shower afterwards.
I will try to reset once it charges back up. I took it off to see if it would dry out some and turn off since setting won't allow me to manually power it off.
Best Answer07-21-2020 11:57 - edited 07-23-2023 05:37
Hi there @Avdra, thanks for getting back and for the update in your reply. I appreciate the details you've shared.
Note that all Fitbit trackers and smartwatches are water-resistant, which means they're rainproof and splash-proof and can stand up to even the sweatiest workout. You can swim or shower with certain Fitbit devices. Fitbit Versa series are Swimproof in a lake, pool, or ocean (up to 50 meters).
Please let me know if you have done what I suggested here so I can move forward to the next step. 😉
Best Answer07-25-2020 11:02
07-25-2020 11:02
After letting it power down on its own and putting it on charge a couple of days later, my versa's display won't turn on. I can tell it is powered on (the dark backlight is there) but no actual display at this point. I wonder if there is any kind of warranty at this point, and what's the best department to reach for that.
It's really frustrating that I would refuse to get it wet but finally gave in and now it's just ruined.
Best Answer09-11-2020 14:48
09-11-2020 14:48
