08-13-2020
03:15
10:48
08-13-2020
03:15
10:48
It's been a month now that the screen of my versa goes crazy. Without any reason the screen is flipping into notifications or exercises screen vinrating in the same time. Quite annoying during sleep and battery consuming. Have tried all recommendations (reset, factory etc.) found in forums but there is no permanent solution for this issue.
08-14-2020 10:51
08-14-2020 10:51
Hi there @makrig01, welcome to the Community Forums. I'm sorry to hear about your Versa's screen behavior, I understand why you'd feel annoying. Thanks for taking the time to try fixing your watch prior to posting here.
At this moment, the limits of what we can do for you here on the public community forums for the issue you're experiencing have been reached, so I've contacted our Support Team on your behalf to look into this issue further and provide you with some options. Please keep an eye on your email inbox for further instructions. Note that due to recent events affecting our operations, support options are limited and wait times are longer than usual.
We hope your issue is solved soon.
06-16-2021 05:05
06-16-2021 05:05
My versa is doing the same thing! We’re you able to fix the problem? I’d love to know how to fix this without buying a new versa. It seems my fit bits only last about a year before something happens ;(
06-17-2021 07:46 - edited 10-07-2024 11:40
Hi there, @SadieGrace. Welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 3. I understand how you must be feeling.
I've seen you contacted our Support Team after posting here and they've already helped you with this matter. If you have any further questions, please feel free to reach out to our team once again.
Have a nice day.
04-19-2022 18:07
04-19-2022 18:07
Same, any tips?
04-21-2022 07:21 - edited 12-31-2023 08:01
Hi there, @MamaBear0609. Welcome to the Community Forums.
Please restart your Versa as suggested here How do I restart my Fitbit device? If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
