07-13-2018 17:49
07-13-2018 17:49
I have had my Versa less than a week and this is the second time I have had sync issues once the battery runs low. It fails to sync. Even after it is fully charged again it does not sync.
The first time I tried multiple troubleshooting steps and no avail.
Including, turning off and on multiple times, unpairing other bluetooth devices, manual sync, deleting app and re-installing etc
In the end I deleted my fitbit app reinstalled, removed Versa link and restored versa to factory settings and re-paired. This at first wouldn't pair the two, but my second attempt worked.
And as a result I lost two days worth of data 😞
Now again this morning (1.5 days later) it has happened again, it does not sync. I have charged the Versa completely, I have turned off phone and versa and re-started. Unsuccessful.
I have an iphone 6 and phone software is up to date. Fitbit app is also latest version.
I do not want to have to restore factory settings every time battery runs low!!!!
Help!
05-20-2020 21:50 - last edited on 09-25-2020 20:38 by LiliyaFitbit
Hi, I am using Samsung s8+This has happened on a number of occasions. I have deleted app etc and reinstalled but still does seem to fix. It eventually comes good again if I restart my phone after reinstalling the app. But it can take a day or more of fighting with it to get it to synchronize again. It is extremely frustraiting. Every time it is left to go flat it crashes. Kind Regards (Sent from my Samsung Galaxy smartphone)
09-05-2020 08:44
09-05-2020 08:44
I have the same problem. I just got my versa2 and i am extremely frustrated. I have done everything...turn it off...reset...taken the app down and downloaded it again...EVERY SINGLE TIME...after low battery charging. I am about to send it back.
09-05-2020 09:23
09-05-2020 09:23
09-20-2020 21:40
09-20-2020 21:40
This was exactly my problem. I recently switched phones. It was connecting to my old phone. 🤦:female_sign: Thank you so much!
10-11-2020 02:20
10-11-2020 02:20
Mine does that same thing all the time. I'm getting tired of it. I had an off brand one for years that never did this and I paid like $10 for it.
11-23-2020 08:13
11-23-2020 08:13
I am having the same issue! I have a Google Pixel 4, and a Versa 2. Every time my battery runs low (like 14% or so) it stops syncing with the Fitbit app, even after it's fully charged. I'm having to uninstall the Fitbit app, reboot my phone, reboot Versa, reinstall the app and add the device again. It takes various combinations of all of the above to get it to sync again! It would appear this is a bug that Fitbit needs to fix with an update!!
11-23-2020 09:08
11-23-2020 09:08
05-17-2021 08:49
05-17-2021 08:49
Thank you sooooo much - that did it for me!
(I've had the same problem for years.)
11-08-2021 19:51
11-08-2021 19:51
I have the same problem. the only thing that re-syncs is installing and re-installing the app on my phone, then re-connecting, re-setting up preferences, etc. It's really a pain.
07-05-2022 06:24
07-05-2022 06:24
Hi I had this issue this morning just incase anyone else is looking for an answer I fixed mine by pressing shutdown on my watch which is just below the factory reset option. Hope this helps someone 😊
09-18-2022 00:23
09-18-2022 00:23
This is happening to me too. Please can I get some support from Fitbit.
