Versa won't sync and is losing time
This is the second time I've had this same issue with this smartwatch. It's not tracking my sleep, it's losing time, it won't sync. I waste way too much time trying to get this piece of garbage to work right. I am done with this thing. I will not buy another one of these watches and I will discourage others from wasting their time as well.
2 REPLIES 2
Hi there, @Tmpete. Thanks for trying to troubleshoot the issue with your Versa. We acknowledge the limitation we have on our part particularly on what you have experienced. We‘re taking into consideration your comments and sentiments with regards to our products and services.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
  • Huawei P8 Lite
  • Huawei P9 Lite
  • Xiaomi Mi 6
  • Huawei P20 Lite
  • See these additional instructions for help resolving any issues using the Fitbit app on this device.
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the following steps:
1. Remove the Versa Lite from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa Lite.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa Lite.
If the issue persists, see Why won't my Fitbit device sync?
Why are you calling the Fitbit Versa "Garbage"? it's not garbage.  It is a great Fitbit watch.
