01-15-2021
05:47
11:54
01-15-2021
05:47
11:54
My Versa won't sync! I uninstalled the app then reinstalled and set up my Versa again. When I click on Versa in my bloothtooth app, it says, "must have app to use this device ". I've held the buttons to force restart on Versa...don't know what else to do.
01-15-2021 07:37
01-15-2021 07:37
Simple, don't go to the Bluetooth app.
To check if your watch is syncing
In the phone Fitbit App Click on profile photo [top left] Device photo [middle left] Sync - See when last synced Try refresh by touching circle it should say "a moment ago" |
if you are having sync difficulties still its a good idea to restart your phone and your watch/
01-15-2021 11:58 - edited 09-08-2024 09:03
Hi there @k2wess! Thanks for trying to troubleshoot the issue with your Versa before reaching out. @Guy_ Thanks for your input!
Before anything else, I'd like you to make sure that the mobile phone you're using is included here Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
However, I'd recommend doing the following:
If the issue persists, please see Why can't I set up my Fitbit device? and Why won't my Fitbit device sync?
Let me know how it goes.
01-16-2021 20:21
01-16-2021 20:21
I tried a those things, now I can't even set my device back up! I've turned everything off and on too many times to count. I removed everything and now, like I said I can't even add my Vera back to my app. On my phone when I click "Versa" in my Bluetooth list, it says I need an app to run this device. Ughhh! My Versa has been connected to my S20+ for over 3 months now and just started not to sync. About ready to throw the thing away!
01-17-2021
03:05
08:55
01-17-2021
03:05
08:55
no matter how many times we are advised to try all the troubleshooting tips the fact is they don’t work! Or you may be able to sync once then can’t again ! I have tried every tip and trick repeatedly and managed to sync ONCE yesterday and my watch is now 2 HOURS slow so useless. Yes my phone and operating system are compatible, yes I’ve done all the trouble shooting tips plus numerous factory resets. We need a fix for this because being unable to sync is making our watches completely useless. Are Fitbit acknowledging there is an issue?
Moderator Edit: Formatting
01-17-2021 09:04 - edited 09-21-2023 03:46
@k2wess @InsulinPixie We acknowledge the limitation we have on our part particularly on what you have experienced. We‘re taking into consideration your comments and sentiments with regards to our products and services.
I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual.
