07-08-2021
14:23
15:04
07-08-2021
14:23
15:04
07-08-2021 15:04
07-08-2021 15:04
Hi there, @Cleary. Thanks for stopping by and for trying to troubleshoot the issue with your Versa before reaching out.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Versa from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa.
Hope that helps.
Best Answer07-08-2021 15:04
07-08-2021 15:04
Hope that helps.
Best Answer07-09-2021 00:30
07-09-2021 00:30
I tried this several times. Only one time I had success. It stopped synchronizing on June, 28th and the one time it worked was July, 6th. I tried to connect via Windows 10 and Fitbit app, with my mobile phone (Samsung Galaxy S9) which worked the last 2 years and I tried it also with my tablet (Android).
There is no connection to my Versa.
If I tried to get in touch with the support, there I read the notification that Fitbit is searching for a solution here.
Have you found something? The steps doesn't work with my Fitbit and it is independent if I change my devices.
Best Answer07-09-2021 03:54
07-09-2021 03:54
Hi there, @DenVisse. Welcome on board. Thanks for sharing the details about the issue with your Versa. I understand where your concern is coming from.
Since you've exhausted all the troubleshooting steps we've provided in the forums, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
07-09-2021 06:13
07-09-2021 06:13
I had this same problem. Have a Samsung galaxy s9. I tried restarting, turning off Bluetooth, turning versa off and back on as this tricks have worked previously. I then uninstalled and reinstalled the fitbit app on my phone and now it's syncing.
Hope this helps!
Best Answer07-09-2021 07:12 - edited 03-20-2024 12:54
Hi there, @Catche6. Welcome to the Community Forums. I'm very glad to hear that you managed to solve the syncing difficulties you were experiencing. Thanks for sharing what has worked for you. 🙂
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
