05-07-2022
06:35
10:49
05-07-2022
06:35
10:49
For the past two weeks I've had trouble syncing my Versa to the app... it's very sporadic, sometimes syncing only when away from wifi. Have they done something recently to the programming? I've gone through all the hoops. Reinstalled the app, restarted the watch, restarted my wifi and bluetooth.. no rhyme or reason when it decides to work... frustrating...
05-07-2022 10:50
05-07-2022 10:50
Hi there, @AnneMarie50. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out. I understand how you must be feeling.
I've seen you contacted our Support Team before posting here. If the steps they provided did not work, please feel free to contact our team back so they continue assisting you.
Have a good day.
05-07-2022 13:11
05-07-2022 13:11
That doesn't answer if there have been any changes to programming to cause all these issues all.of a sudden. I've had this watch for 2 years with no issues and all of a sudden there are these challenges. I've already spent hours with all the shut this, do that, try this sequence. Calling in fixed the problem at the moment but not long term.
05-07-2022 13:55
05-07-2022 13:55
@AnneMarie50 No changes have been made to the Fitbit devices software. Nevertheless, if you're syncing with an Android phone, please make sure it meets the requirements listed here as the requirements change every now and then depending of your phone's OS.
See you around.
05-07-2022 16:04
05-07-2022 16:04
Same issue here. I turn my phone off every night and my versa does not connect automatically anymore when turning on.
👉2 things have happened in the last f/n THAT MIGHT HAVE INFLUENCED THIS
Samsung update 2 weeks ago
Google play update 2 weeks ago
I have checked all settings. Background usage, Bluetooth etc, but cannot find the issue. Tried all this
05-08-2022 06:21
05-08-2022 06:21
Heavy check mark here as well... like that. Can Fitbit please see if the Google and Samsung updates might have affected the downloads? I just erased everything and started from scratch last night, checked updates and it is still not syncing this morning.
05-08-2022 16:35
05-08-2022 16:35
05-09-2022 18:44
05-09-2022 18:44
What do you mean by opening up the app to make it sync for the rest of the day? I will open the App and it still.doesnt sync. Today I had to leave my house and the wifi to get it to sync with my dats... for your location, maybe if you open the settings fir phone<location or Apps in settings.
05-10-2022 07:24 - edited 11-10-2023 05:31
@AnneMarie50 @Jo.aus Thanks for trying to troubleshoot this issue. I understand where you guys are coming from.
As mentioned in my previous post, I've seen you both contacted our Support Team already. If the steps they provided did not work, please feel free to contact our team back so they continue assisting you.
Thanks for your understanding. Have a good day!
05-10-2022 12:12
05-10-2022 12:12
Hi Everyone,
I many have found an easy solution, more than everything else..
i found that if you reset passord on a PC , to fitbit login screen, use the 'forgot password' link
get the email, follow link and use the password criteria set out for you, ie must have capitol and lower case letters, number and special character,
(you may not have had a special character in password before..)
then login into website from computer, then login phone with new password and win win winner,
it should link-up to your watch/device for you automatically
hope this helps, **ahem** new security count-measures..
regards
Nigel
05-10-2022 15:39
05-10-2022 15:39
I had the same problem early today. I did all the same steps that you followed.
Did you restart your phone? I decided to do this and I was able to get it to work.
05-12-2022 06:21
05-12-2022 06:21
I have tried restarting the phone several times.
I did discover that my Versa is not syncing with the App while.on wifi... I have to leave the vicinity of my wifi to get it to sync using my data. Even if I gave permission to the App to always use data if wifi is around. Now that I've narrowed it down, I'll try tech support again. Appreciate all the community assistance!
05-12-2022 15:10
05-12-2022 15:10
Very strange indeed.
Good luck and I hope that tech support can help you.
