05-01-2018
19:11
05:01
AlejandraFitbit
05-01-2018
19:11
05:01
AlejandraFitbit
I've had my Versa since Saturday and I does not want to sync with my Samsung Note 8. I have done the soft reset, factory reset, uninstalled the app and reinstalled, restarted my phone and turn the Bluetooth off and on and it still wont work. Should I return it?
02-05-2019 22:19
02-05-2019 22:19
02-17-2019 12:04
02-17-2019 12:04
Hello!
I have a solution that worked for me and posting it for others to try. I deleted all of my previous fitbit devices from my mobile app and it worked! May work for you all, too.
I was really kicking myself for not doing more research before buying my Versa, as it appears that the device doesn't work well with the Note 8. It wouldn't sync steps and I couldn't receive notifications on my watch from my phone. I had a very annoyed first day with my Versa. The next morning I noticed my fitbit app was trying to sync with my One, a device I hadn't used in years. Deleted that and also deleted the Flex 2 the Versa was replacing.
07-20-2019 14:33
07-20-2019 14:33
Stayed on the phone over an hour with tech services to be told Samsung Note 8 is not compatible but IS listed as compatible device on website. Had a Versa which worked great for 6 months then the battery stopped holding a charge. The replacement will not pair nor sync & it is apparently trash at this point. The company will not offer any real help. VERY DISAPPOINTED!!! Supervisor didn't really care what I thought.
09-25-2019 14:20
09-25-2019 14:20
Yes! The same exact thing is happening to me. Extremely disappointed. I have had a fitbit for over 5 years!!
09-25-2019 14:33
09-25-2019 14:33
09-25-2019 15:21
09-25-2019 15:21
09-30-2019 17:33
09-30-2019 17:33
Let us know how! Please
11-13-2019 06:59
11-13-2019 06:59
I had a customer rep for FITBIT tell me the Galaxy note 8 is not "completely" compatible with the FITBIT Versa.
The all the other Note editions or versions are "just not the note 8" no further expatiation was able to be given.
12-17-2019 14:14
12-17-2019 14:14
I have a Samsung Galaxy note 8 and have had several issues as well, not syncing, not getting notifications, Alexa disconnecting. I ended up returning and went back to my HR Charge 3, with which I have not problems. Hopefully FitBit will do some sort of software/firmware to improve. Not going to out a buy a new phone to the cost of $1,000 or more just to be able to have the Versa 2 work.
12-26-2019 10:35
12-26-2019 10:35
How? It doesnt list Note 8 as even being compatible
12-26-2019 10:37
12-26-2019 10:37
It was working great earlier for me in May/June, then it just stopped 😞 That's when I learned Note 8 was not compatible.
12-26-2019 12:59
12-26-2019 12:59
Thank you I ended up returning and going back to using my HR Charge 3
