07-13-2018
18:13
08:13
AlejandraFitbit
07-13-2018
18:13
08:13
AlejandraFitbit
Had my Versa for a month worked okay now it won't sync at all. Did all the resets, forget device, Bluetooth, restart Versa, restart phone, re-installed the app, it finds the Versa get to the pin screen now I can't get past the pin screen put the pin it will get stuck on connecting and the Versa will just restart itself and says not working.
Moderator edit: subject
07-27-2018 01:13
07-27-2018 01:13
Bought ticwatch pro all good now
07-16-2018
08:14
12:23
07-16-2018
08:14
12:23
Hey @Zivko, it's great to see you around.
I appreciate all the efforts in trying to fix the syncing issue you are experiencing. I recommend taking a look at the help article Why won't my Fitbit device sync? and follow the instructions provide there.
I hope this helps, let me know the outcome. ![]()
07-21-2018 05:40 - edited 07-21-2018 05:42
Didn't mean to bump my post was in hurry and the versa was **ahem**ting bricks
Versa still drops connection for notifications (yes sync all day + always connected & keep alive widget) no notification come through the watch.
Made sure both versa and phone were fully charged, tried all the reset restarts and deleting it's still persistent.
Sometimes it will vibrate and restart it's self
Restarting versa or Bluetooth fixes the issue for about 10 min.
On the other hand it's tracking sleep steps etc
Thanks
Best Answer07-27-2018 01:13
07-27-2018 01:13
02-07-2019 09:56
02-07-2019 09:56
I have tried everything suggested to get my Versa to sync and used several devices but nothing happens. I have contacted Apple and they can't do anything. When I try to sync it says connect to Blue Tooth and my Blue Tooth turns on but won't sync with my Versa. Same thing happens when I try to sync with Blue Tooth on my Kindle, won't recognize the device. I'm extremely frustrated!
Best Answer02-07-2019 12:27
02-07-2019 12:27
I read the article and tried everything mentioned. Still no syncing.
