09-13-2018
18:57
08:34
AlejandraFitbit
09-13-2018
18:57
08:34
AlejandraFitbit
All of a sudden my watch and phone stopped syncing. Not sure how to fix it.
Best Answer09-14-2018 00:26
09-14-2018 00:26
I would try restarting your phone and then restarting your fitbit using this procedure:
You might also try forgetting the fitbit in your phone's bluetooth settings. If it still won't sync after that then there are some more ideas to try in this help file: https://help.fitbit.com/articles/en_US/Help_article/1866/
09-16-2018
08:35
17:13
09-16-2018
08:35
17:13
It's great to welcome you @Lamplighter and @SteveH thanks for stopping by.
I would like to know if you keep having issues with your Versa? Have the instructions provided by our friend worked?
Hope to hear from you soon. ![]()
Best Answer09-16-2018 11:44
09-16-2018 11:44
Same thing happened to mine. Working fine then as of 3 days ago, won't sync. Well, some data is coming thru to app but won't sync fully. I've tried everything and I'm now left unable to add my versa back onto the app which renders it's useless.
