08-03-2020
15:41
07:54
08-03-2020
15:41
07:54
My versa won’t track my heart rate or sleep. I have tried restarting my fitbit, making sure the heart rate is turned on, and I have taken off my band and reattached it. Please let me know anything else I can do.
08-04-2020 07:59
08-04-2020 07:59
Hi there @katherinedercol, welcome to the Community Forums. Thanks for the details provided in your post and for letting me know about the difficulties you've been having to track your heart rate and sleep. I appreciate you've taken the time to troubleshoot this issue prior to posting here, I'll be glad to help you.
As you may know, sleep stages are based on heart rate data, so make sure that you're getting a solid heart rate reading , since sleep stages requires consistent HR. For best results, wear your device higher on your wrist (about 2-3 finger widths above your wrist bone). The band should feel secure but not too tight. Also, double check that your watch is charged up.
Additionally, I'd recommend checking the following that could be preventing you from receiving sleep stages:
For more information about why you see your sleep pattern, tap or click the sleep record that shows your sleep pattern.
On the other hand, I'd appreciate if you can confirm that you've tried troubleshooting the heart rate as suggested below:
Also, for more detailed information, see: What factors can affect my heart-rate reading on my Fitbit device?
I'm looking forward to your response, keep me posted.
08-04-2020
09:54
10:50
08-04-2020
09:54
10:50
Hi! I tried turning off my heart rate monitor, syncing it to my device,
turning on the heart rate, re-syncing, and then turning the device on an
off. It still wouldn’t work. I think that the problem started after I
updated my Versa. I don’t know what else to do.
Moderator Edit: Personal info removed
08-04-2020 10:55 - edited 10-12-2023 18:18
Hi there @katherinedercol, thanks for getting back and for the update. I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
