08-22-2018
20:49
05:51
AlejandraFitbit
08-22-2018
20:49
05:51
AlejandraFitbit
My Versa hasn't tracked my sleep for the past two nights. I have entered my sleep manually, but no sleep stages or other info. This is one of the reasons I got a fitness tracking watch. Seriously considering sending it back to Fitbit for a refund.
08-29-2018 18:36
08-29-2018 18:36
Restarting it several times didn't work, wearing it higher on the wrist didn't work.
1.Heart rate monitoring is sketchy , at best.
2.Tracks flights of stairs very inconstantly (I climb the same structure over and over throughout my shift at work and it varies the "flights" I have climbed each time from 3-9).
3.Won't track sleep.
Three strikes, you're out. I am returning all Fitbit items. Shameful, considering that FitBit is widely considered the standard in fitness tracking devises. #goinggarmin
08-22-2018 20:58
08-22-2018 20:58
Trackers do miss some nights and some nights your body interfers with the sleep tracking. I was not well a few weeks back and got no sleep tracking. Restart your Versa several times and see if that helps tonight.
Helen | Western Australia
08-23-2018 05:52
08-23-2018 05:52
Great to have you here @Rattlerlv and thanks for the input @NellyG.
I appreciate the efforts in trying to fix this. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
I hope this helps, catch you later.
08-29-2018 18:36
08-29-2018 18:36
10-28-2018 10:21
10-28-2018 10:21
my versa Fitbit wont tracking my sleep
01-15-2019 13:29
01-15-2019 13:29
How is 'returning the product' a solution??? Be nice if fitbit fixed their sleep tracking problem or at least admitted there was one!
01-15-2019 13:30
01-15-2019 13:30
And yet none of these scenarios applied to me and my versa is still not tracking my sleep after your update!
03-02-2019 11:58
03-02-2019 11:58
I’m having he same problem. The heart monitor doesn’t seem to work. It always shows my heart rate between 70-80 even when I’m doing cardio and my other monitor shows it accurately around 140-160. The verse won’t track my sleep at all. I have been putting my old Fitbit blaze on at night to track my sleep.
03-02-2019 15:55
03-02-2019 15:55
That's so frustrating. I kept working with their support until they kept asking me to perform the same 'tests' for a third time. Then I wanted it escalated and then I got the replacement notification.
My update: I have a replacement versa - that I have NOT done the firmware update on and it tracks everything perfectly. Sleep included.
I won't be doing this version of the firmware update.
03-02-2019 16:00
03-02-2019 16:00
BTW everyone - even though this solution is marked as 'solved' it is NOT! Unless the solution is to return 'all Fitbit' devices.
03-03-2019 15:02
03-03-2019 15:02
can i get back to the previous firmware somehow??
08-16-2019 19:57
08-16-2019 19:57
So has anyone figured out how to get the sleep tracker to work on the versa
09-10-2019 18:32
09-10-2019 18:32
I’ve had mine for about 8 months now, and literally just 3 nights ago stopped recording my sleep intermittently. I’m so sad. 😞
09-19-2019 15:02
09-19-2019 15:02
I just got the Versa 2 and the last 4 nights it hasn't tracked my sleep either. I was having a hard time getting it to pick up my heart rate and I wasn't getting notifications. Everything works fine except it tracking my sleep as well.
10-14-2019 08:42
10-14-2019 08:42
Have a new Versa 2, and I'm not getting sleep stages. All else works. Have tried all placements on wrist, doesn't help. Anybody found a successful way, or is it a problem with the Versa 2.
10-14-2019 09:26
10-14-2019 09:26
Have you had any success with sleep stage monitoring, or just basic data. I just replace a Blaze that I had for over two years and it was usually successful but began failing in various areas, including sleep stage and syncing. The Versa 2 works in every way except sleep stages....
10-14-2019 12:59
10-14-2019 12:59
The solution was that they replaced the hardware - it was the only thing that worked. But I had to really be persistent with my complaints about the issue. There is no clear process for formalising complaints and it is difficult. But persist - no amount of restarting, wiping data, and restarting did anything but take up my time and frustrate me.
10-14-2019 13:01
10-14-2019 13:01
This is marked as 'answered' and that there is a 'best answer'. The only answer is, if you have tried everything suggested, to insist that the hardware be replaced. I got the same 'automated' reply everytime I asked for help. I got tired of that and insisted something more permanent be done. They replaced the hardware and it as worked seemlessly since.
10-24-2019 12:00
10-24-2019 12:00
01-09-2020 05:57
01-09-2020 05:57
Mine started having problems with sleep tracking four nights ago. I go to bed between 11:30-12:30 but tracking doesn't kick in until 3-3:30am suddenly. I've only had this thing a month. I'm very disappointed.
