05-02-2019
23:07
07:49
JuanJoFitbit
05-02-2019
23:07
07:49
JuanJoFitbit
Hi. I've got a Fitbit Versa. I have reset my device to the factory settings as it wasn't syncing after I got a new phone. I am now struggling to get it to switch back on. I have tried to charge it several hours and pressed the two buttons as advised but I have had no luck. Anyone that will be able to help please?
05-03-2019 11:00 - edited 05-03-2019 11:03
hi, try to switch your Versa on by long pressing only the left button untill you see the Fitbit logo appearing. Might also be when this works that you do not get the Fitbit logo, but the activity screen in which you can set you screen to switch on automatically, etc.
05-05-2019 12:54
05-05-2019 12:54
Still no luck 😞
05-06-2019 07:48
05-06-2019 07:48
@CarynMeyer Welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it won't turn on after restarting it and trying the factory reset.
I'd like you to try cleaning the contacts of your Versa and charging cable with a cotton swab. This will remove any dust that the contacts accumulate. After this, charge your tracker for 2-3 hours and see if the display comes back to life.
Thank you for your help @SunsetRunner!
Keep me posted!
11-01-2020 11:24
11-01-2020 11:24
I reset my Fitbit Versa back to factory settings and now it will not sync. The message says 'data not cleared - try to sync again.' I cannot get the message to clear. The Bluetooth is on my phone and paired. How do I get it to reset? Pressing the buttons will not go back to Fitbit home screen.
Thank you
Bobbie Saunders
11-03-2020 10:04
11-03-2020 10:04
Hi @bjbenz, thank you for joining us in this thread and our Fitbit Community. Let me help you with your Fitbit Versa since it shows a "Data not cleared" message. I understand how you feel about this and I appreciate the time spent trying to get this issue resolved before contacting our forums.
In order to avoid providing the same information, let me know if the factory reset was performed as described below:
Let me know how it goes.
