06-20-2020
07:02
03:06
06-20-2020
07:02
03:06
OK...so I've had this Versa for over a year (for the warranty question). This is my 5th fitbit product, so I'm pretty versatile in the fitbit products. Since the most recent update (I think about a month ago or so...can't remember when), my Versa has been just turning off on it's own and not turning back on until I do the 2 button (left and bottom right) press. I've looked through all these posts and google searches...I've tried re-syncing, turning it off/on, verifying all settings, and everything else people suggested without success. Finally, today I did a factory reset. I now cannot turn it back on. Tried the 3 button push and the 2 button push for various time intervals on each. I know it's charged - it was 65% when I did the reset. Tried letting it sit in the charger for an hour...nope...nothing.
I don't know what else to do. I've tried everything that everyone has suggested.
06-20-2020 16:47
06-20-2020 16:47
JuanJoFitbit...you answered everyone else's post but mine...thank you. 😞
06-20-2020 17:37 - edited 06-11-2024 09:31
Hi there @SunsetRunner, welcome to the Community Forums. I'm sorry to hear about your Versa 's recent behavior. I appreciate the details shared in your post and for taking the time to troubleshoot it prior to posting here, I'll do my best to help you.
While reading your posts, I wondered if your watch vibrates when you put it on the charger? It seems that the Factory Reset drained the battery and also looks like the battery may not be charging properly and therefore does not turn on. So, I recommend that you follow these steps:
06-20-2020 19:09
06-20-2020 19:09
Hi MarreFitbit.
I have a Versa not the lite. I have tried troubleshooting the charging potentials. It does not vibrate when I put it on the charger. The connection points on both side are good and clean - I've checked and cleaned already. It was on the charger today for 7hrs...no change.
06-21-2020 03:12 - edited 04-21-2024 11:27
Hi there @SunsetRunner, thanks for getting back. I updated my previous post, sorry for the misunderstanding.
I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
