06-19-2020
21:15
09:39
06-19-2020
21:15
09:39
After having issues with the HB not working tried everything. Did a shut down and restart multiple times. Deleted from account and ended up having to do a factory reset. Now it will not turn on for anything. Please help.
06-20-2020 09:45 - edited 06-11-2024 09:33
Hi there @Kelbystanley, welcome to the Community Forums. Thanks for the details provided about your Versa's recent behavior and for taking the time to troubleshoot your watch prior to contacting us.
While reading your posts, I wondered if your watch vibrates when you put it on the charger? The battery on your watches may not be charging properly and therefore does not turn on or even is causing a battery drain. I recommend that you follow these steps:
Keep me posted, I'll be around.
Best Answer06-20-2020 10:48
06-20-2020 10:48
Best Answer06-20-2020 12:28 - edited 04-21-2024 11:31
Hi there @Kelbystanley, thanks for getting back and for the update. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since due to recent events affecting our operations, support options are limited and wait times are longer than usual.
