08-12-2020
22:43
11:20
08-12-2020
22:43
11:20
I had done the factory reset in my fitbit versa
After that I unable to switch on the device whenever I charging is over in that device it was showing O% on the display
After keeping the charge it was not switching on
08-13-2020 11:25 - edited 10-03-2023 17:27
Hi there @Rupeswar, welcome to the Community Forums. I'm sorry to hear that your Versa smartwatches aren't turning on after a factory reset. Thanks for the details provided, I'll be glad to help you both.
While reading your posts, I wondered if your watch vibrates when you put it on the charger? The battery on your watches may not be charging properly and therefore does not turn on. If you haven't done so yet, recommend that you follow these steps:
