12-28-2021
18:36
18:25
12-28-2021
18:36
18:25
My Fitbit versa lite will not turn back on after I did a factory reset. Nothing happens when you hold down button.
01-07-2022 18:27 - edited 01-08-2024 05:10
Hi there, @Dlchase1028. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa.
Regarding the issue you're experiencing after the factory reset, I was wondering if you felt any kind of vibration when performing either the restart or factory reset? If you didn't, please try the steps below:
If the above steps don't work, at this point I recommend doing a manual factory reset with the steps below:
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
Hope that helps.
Best Answer01-07-2022 18:27 - edited 01-08-2024 05:10
Hope that helps.
Best Answer03-21-2022 10:47
03-21-2022 10:47
But versa lite only has one button
Mine wont show anything even when i press the button
