02-16-2023
08:20
12:35
02-16-2023
08:20
12:35
Hi everyone, has anyone experienced a versa not switching on after a factory reset?
02-18-2023
10:45
10:21
02-18-2023
10:45
10:21
Hi @AshSwan - yes, this can happen due to a bug in the factory reset process, unfortunately there is nothing available that will fix it.
If you do decide to replace it and used it for notifications and HR, go for the cheaper Versa 2 which is less problematic and is more functional than the later watches. Don't forget to look at other brands with better battery life and working features not found on Fitbits.
Best Answer02-20-2023 10:18
02-20-2023 10:18
Hi @Guy_ did they fix it for you?
Best Answer02-20-2023 10:21
02-20-2023 10:36
02-20-2023 10:36
@Guy_ That's not how it works in the USA, where Fitbit is based. Normally after your return period, you have to go through Fitbit support for a warranty replacement. Not where ever you bought it from.
Best Answer02-21-2023 12:26
02-21-2023 12:26
Thanks so much. I’m from South Africa so it will probably be more difficult for @Fitbit to actually care
