12-20-2021
11:04
11:59
12-20-2021
11:04
11:59
I did a factory reset on my versa on Saturday December 18th and since then it has stopped working. The screen is black and I have charged it for at least 8 hours a day since then but it still won’t turn in. I even did the 3-button reset method, but that was of no use. So I was wondering what could be wrong with it. Please respond ASAP so I know what I should do.
12-20-2021 12:07 - edited 06-23-2024 06:52
Hi there, @Ayushi22. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out.
As a first approach, I'd recommend restarting your Versa. For instructions, see How do I restart my Fitbit device?
If that doesn't work and your Versa doesn't vibrate when performing the restart, please try the steps below:
Hope that helps.
12-20-2021
21:03
08:49
12-20-2021
21:03
08:49
Thank You! I will try this for sure tomorrow.
Update: It did not work. Thanks for your help.
12-24-2021 08:49 - edited 11-14-2023 04:02
@Ayushi22 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
We hope your issue is solved soon.
12-25-2021
19:01
08:33
12-25-2021
19:01
08:33
