12-31-2019
13:40
06:14
JuanJoFitbit
12-31-2019
13:40
06:14
JuanJoFitbit
I went to settings on my Fitbit versa and shut it down but now it won't turn on. I have tried charging it, pressing the buttons, but nothing is working how do I turn it back on.
Moderator edit: format
12-31-2019 15:48
12-31-2019 15:48
Try restarting several times. If that doesnt wake it up try a semi factory reset using the buttons (see below). If that doesnt wake it up then I think it has died and all you can do is contact support and see if they can help you.
SEMI FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up. Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
01-21-2020 08:07
01-21-2020 08:07
I have had the same issue twice now. I had shutdown my versa and immediately tried to turn it back on with no luck. Just keep trying with holding down all 3 buttons. Eventually it will work.
01-30-2020 09:40
01-30-2020 09:40
I have the same issue. I cannot turn off my Versa (first gen) without having to do a hard reboot to get it to come back on. Then I have to go through all the issues of it not syncing...sometimes even having to "remove" it from my app and add it back in like a new device. This started about 2 or so months ago and is a total pain! Wonder if there is a warranty....
01-30-2020 10:13
01-30-2020 10:13
Thank you so much, this worked for me first time! 😀
Best Answer01-30-2020 15:59
01-30-2020 15:59
Hi @johnnyk71 Yes therebis a waranty on Fitbits. For most ofbthe world it is 1 year, except for Europe and Australia where it is 2. You need to contact Support to discuss your warranty
Best Answer04-11-2020 20:38
04-11-2020 20:38
Thankyou
Best Answer04-11-2020 21:18
04-11-2020 21:18
Thanks, it worked for me
Best Answer05-17-2020 04:01
05-17-2020 04:01
how to restart my versa
Best Answer05-24-2020 12:02
05-24-2020 12:02
Thank you so much!! That advise solved my problem!
05-25-2020 06:13
05-25-2020 06:13
Hi everyone! due to the recent events, I apologize for the delayed response. However, I'm glad to hear that the troubleshooting steps that my friend @NellyG were helpful and helped you to get the issue resolved. Thank you for posting the updates here. Don't hesitate to get back if more assistance is needed.
@bobbyairborne, welcome to our Fitbit Community. Regarding your question, please follow the steps listed in this help article in order to restart your Fitbit Versa.
I'll be around if any question arises.
Best Answer05-31-2020 08:31
05-31-2020 08:31
Best Answer06-02-2020 08:46
06-02-2020 08:46
I shutdown my vera and I am not able to turn it on. I have followed thr reset directions, charged the watch, etc. I'm not sure what else to do. I used the watch last night for a workout. I went to the app to look at my stats and realized it didn't sync. I tried to update the app and it didn't. So, that's why I shutdown the watch. I haven't had any issues until now it will not turn on. I'm not sure what to do.
Best Answer06-16-2020 05:24
06-16-2020 05:24
The exact same thing happened to me last night, which is how I ended up here looking for advice.
Best Answer06-22-2020 08:20
06-22-2020 08:20
Thank you. This really helped. I had trouble turning on watch after shutdown. Press all 3 buttons then tried the back button again.
Best Answer07-20-2020 10:50
07-20-2020 10:50
Hi Lizzie
I have been trying this option for a day now. My fingers are numb and still no luck:(
07-20-2020 10:55
07-20-2020 10:55
Hello
I have the same problem. Tried pressing the buttons, no change. Disappointed.
Best Answer10-11-2020 10:47
10-11-2020 10:47
What is the back button?
Best Answer12-30-2020 14:06
12-30-2020 14:06
Hi Nelly,
Thanks, the strategy works Very well, but not sure if you realised you can also use that to power on the Fitbit and check it's battery power. But yes that works if you can't use the power button only.
*Fitbit Versa - 1st Edition - may apply to others*
Best Answer12-30-2020 14:10
12-30-2020 14:10
@Billp2000 Oh that's not good... but I think the hole isn't for resetting, but of course you can try. However have you tried holding all 3 buttons, 12 seconds? Also try charging your Fitbit again because even though I was on 65% battery, that plummeted down to zero the next morning after I tried to reboot it.
