01-10-2021 17:03 - last edited on 01-11-2021 17:39 by LiliyaFitbit
I wore my 3 year old versa in the hot tub for almost an hour. I can’t get it to turn on now. I’ve tried charging and reseting it but nothing! Is it broken forever?
01-10-2021 22:52
01-10-2021 22:52
Unfortunately.
They are sensitive to hot water.
You can check with a magnifying glass looking through the holes on the back, you will probably see condensation.
It will dry out eventually but will/may not work properly after. Depends on your patience and how much you miss it.
Sorry, I had the same issue and replaced it.
Best Answer01-10-2021 23:47
01-10-2021 23:47
The screen is glued on, hot water may not be good, but the Versa is not rated to be put into strong currents.
